Phone won't register with network after returning from Morocco
Andrew240
8 REPLIES 8
Leanne_T
Hi @Andrew240
Thanks for coming here.
Which model phone are you using?
Are you with us on pay monthly or pay as you go?
Leanne 🙂
Are other EE phones in the same location receiving service?
Hello! I'm using a Pixel 4
Hello! I'm on a Pixel 4
Yes they are. I've travelled from Gatwick home and had the same issue the whole time. I don't usually have any problems with signal here.
Christopher_G
Have you tried restarting your phone, @Andrew240
Another test would be to try manually connecting to EE. Tap Settings > Network and Connections. The option should be in there.
Thanks Chris. I tried both of those things and still couldn't get it to connect. Even when I tried to manually connect it said unable to connect.
Christopher_G
Could you try manually connecting to another UK provider, @Andrew240?
It will come up saying the connection has failed. Then try connecting manually back to EE.
Let me know if that works?
