02-11-2022 07:10 PM
hey guys so i recently got the ee 5g router because i live in the middle of nowhere but luckily i have a 5g mass near me, i am getting 80-130 mb download but would like to up it which ee said i could benefit off an antenna but i want to buy and fit my own could anyone recommend which one to get
04-11-2022 04:05 PM
Thank you I’m not sure how to navigate this never used it before haha
04-11-2022 05:37 PM
SIM status:
SIM PIN Verified
Connection status:
Connected
Disconnect
Network name:
EE
Network type:
5G
RSRP:
-111 dBm
RSSI:
-99 dBm
Band:
B3+B7+B3+B1+N78
Is this correct.
04-11-2022 06:45 PM
Ok. yes that's fine. I'm out till quiet late now so I will respond later.
Ideally does it also show the Cell ID or Mast enBID numbers.
04-11-2022 08:10 PM
no problem thank you is this it
05-11-2022 10:11 PM
Did you manage to take a look
07-11-2022 10:53 PM
Was the one I posted adequate ?
08-11-2022 12:06 AM
Hi, first off, sorry for the delay
@lowdown94 wrote -
Network type: 5G
RSRP: -111 dBm
RSSI: -99 dBm
Band: B3+B7+B3+B1+N78
Cell ID: 7462912
Ok, so let's start with the Good News, the good news is .....there isn't much Bad News, you're picking up and getting good 4G+ (4G LTE Advanced) and 5G.
On the 4G side you're getting good CA (Carrier Aggregation) your Router is Registering on Band 3 (1800mhz PCi 208) and getting additional CA on Band 3 (1800mhz), Band 1 (2100Mhz) and Band 7 (2600Mhz). On the 5G side you're Picking up Band n78 (3500Mhz), this Signal Info is all good stuff. The 5G n78 Band is the better of all of EE's 5G Bands, again good news, it's the one to have for best Bandwidth and hence speed, despite that fact that it's a bit of an odd ball in its own frequency compared to the normal 4G Bands and this is where it's important to source and install the correct Antenna(s).
Going slightly Off-Piste here, a quick average calculation of your available bandwidth is, on 4G, 20+15+15+20 Mhz and 5G, 40 Mhz so an average Total of over 100mhz, all very techy but again this is good news and should provide a fairly decent and more to the point consistent download speed quality for your Router.
From the information you provided your Router is Registering on its Cell ID 7462912 and firing Sector 0 to you, which is an EE mast located at Sunnydale Nursery, Mansfield Woodhouse, this EE Site seems to be recently updated from an original 4G to a newer 4/5G mast which is also a bonus as your 4G registration and the 5G NSA Signal layer are coming from the same Mast, so this in effect rules out the need for 2 separate External Antennas to cover two different Site locations, meaning you can concentrate your External Antenna for both 4G and 5G using a single Antenna setup in the same direction.
08-11-2022 12:10 AM
Have a look at my above post Re your Cell ID location and recommendations, and I will look at your suggested Antenna (Poynting specs) and post back in the morning.
08-11-2022 10:00 AM
Hey that’s for the detailed reply, yes all that tech talk is very confusing for me 😂 but I’m glad it’s good news for once not bad Mansfield wood house nursery is about a mile from me so not to far, this was the antenna I was looking at no clue if it’s any good https://www.solwise.co.uk/5G-XPOL-1
09-11-2022 10:58 PM
Need something good asap my signal keeps dropping so really need antenna I guess
