WiFi calling not working well
Fatbob78
Hello, we’ve just moved house, and, the new house has very poor mobile signal.  We’ve both got IPhones, one 13 and one 14 Pro and they’ve both got WiFi calling enabled., both show “EE WiFicall” when swiping down from the top right, but when making or receiving a call, the quality’s very poor, like WiFi calling isn’t working.
We have reasonable broadband from BT, 70Mbps down and 12Mbps up, with Deco x90 WiFi and a bunch of deco M5 satellites, with speed tests reporting good throughput and latency in various locations around the house.
Turning airplane mode on / off sometimes helps.  It’s like the phone thinks the mobile signal is good enough, but it’s really not (one bar).  Is there a way to improve this experience or better, could EE upgrade the mast 😉
12 REPLIES 12
Fatbob78
The coverage checker reports that we’d get good outdoor coverage and mixed indoor coverage,  which isn’t true, it doesn’t matter where I stand…
if I look on the coverage mail, all the nearby villages have poor signal and the farmers fields have strong signal…
Leanne_T
Hi @Fatbob78
Thanks for coming here 🙂
Have you checked the status of your postcode on our coverage checker? If you select 'check status' this will let you know if we're aware of any problems in your area.
If nothing is showing you can report the problems you are having to get this looked into.
Leanne 🙂
Northerner
Hi @Fatbob78
Iphone wifi calling is poor becase any whiff of a mobile signal and it tries to transfer over which in my experience fails. You are better off connecting directly to the router as well rather than via a network .
As @Leanne_T  says have you checked for mast issues locally.
chistery
Try staying in airplane mode and turning wifi back on. Make a call, what's the quality like?
Fatbob78
Thanks all,  issue reported online as no known mast issues in the area
will try the airplane mode on / Wi-Fi on test to confirm it works ok on broadband
Connecting directly to the router or via the mesh network makes no difference to the quality
Leanne_T
Hi @Fatbob78
I would suggest getting in touch with our technical support team on 150 and they will get this looked into further for you.
Leanne 🙂
I will do, as I can confirm, if I turn off cellular (eg airplane mode / Wi-Fi on) that Wi-Fi calling works fine
Leanne_T
Let us know how you get on after getting in touch @Fatbob78
