Whenever i try to make a phone call it says not registered to network
Reginald5
@Reginald5 : Can you send texts or use data?
No I'm unable to send texts or use data.The only way I can communication is via WhatsApp calls which is not enough
 Have you Check service status having given your post code there on the Network Status Checker and reported your problem via that link?
@Reginald5 wrote:
No I'm unable to ... use data.The only way I can communication is via WhatsApp calls
WhatsApp is an internet-app which uses data for its connection.
Both your phone & EE's network treat all usage of apps for what they are - data usage. Usage is not handled as calls.
