22-01-2025 09:23 PM
Ee getting worse and worse. Network status showing 4G+ network but no internet at all. Getting touch with anyone is hard. AI useless..
22-01-2025 10:37 PM
Is this in one specific location or multiple?
Use "check service status" on https://ee.co.uk/help/mobile-coverage-checker as a first check, if this is location-specific.
23-01-2025 06:17 AM
23-01-2025 08:30 AM
@Attila123 wrote:
The reality I don't have good coverage at all
You mentioned in your first post "network status showing 4G but no internet", your second post says "don't have good coverage" - these appear contradictory.
Can you perhaps clarify the exact issue you're having, putting on-screen bars aside? Do you have problems using your phone for, say, calls or data, when coverage is shown? Or zero displayed coverage when you previously had some?
23-01-2025 08:33 AM
23-01-2025 08:52 AM
If you have "almost full bar" that's not a coverage issue, proven by calls being OK.
Slow data speeds are a different issue, but the clarification is helpful. Do speeds vary from time or day? Have they reduced progressively or is this a sudden change?
Use the "check status" option on https://ee.co.uk/help/mobile-coverage-checker as a first check for any "cliff edge" losses of coverage
23-01-2025 09:15 AM - last edited on 23-01-2025 11:26 AM by Christopher_G
There is no time difference at all. Day, night, morning, evening same slow
Internet speed.
[Mod edit: Cleaned up undeliverable email information]
23-01-2025 09:33 AM - edited 23-01-2025 09:52 AM
Looks like you've tried to reply to this forum post using your phone's email program, and the outcome is a tad messy. I think I can see you saying that speeds don't vary - which would be unusual for a normal congestion issue.
Do you get similar issues in other locations? Have those speeds reduced suddenly or is it more gradual?
Try replying by using the website "reply" function at https://community.ee.co.uk/t5/Mobile-Network-discussions/Useless-network/m-p/1499125
