Unusable signal strength
Docomar750
I have an iPhone 15 pro max when on 2 bar signal both 5g and 4g are useless I can’t do anything on line nothing ever loads had this for a while getting fed up
2bars is absolutely not "unusable" by any stretch. The on-screen bars are a very basic guide to signal quality, but what you've described sounds like a data speed issue. And if so, that has nothing to do with signal strength & everything to do with capacity.
Can you make & receive calls OK? Can you send & receive texts OK?
Assuming this is a capacity/speed issue - is it specific to any particular geographical location? Or is it more generalised?
Northerner
Hi @Docomar750
Try restarting your device.
If you're in a poor signal area then it will be the same situation with any carrier.  If this is just at home can you connect to EE WiFi calling service.
