Unable to make calls
GeorgeCochrane
Help please unable to make calls
@GeorgeCochrane   Do you have a signal showing on your device?    Have you checked the EE status checker HERE   ( click the check status tab )   can you send text messages?  Can you access the Internet on your device?
Signal shows full. Unable to use mobile data / send text. Phone says "not registered on network" when trying to make calls.
Had someone try set up a new sim on Friday that wasn't me.
Phoned customer support and they did they had it sorted....
Sent from Outlook for Android<>
Hi @GeorgeCochrane
Are you in the UK?
Is your device unlocked and not blocked?
