Phone signal connectivity in my house .
char109
hi ,I'm having problems with my phone connectivity in certain parts of my house . Can anyone suggest possible solutions ?
What connectivity issues are you having?
No network will guarantee 100% national indoor coverage, and WiFi-calling is a good solution to indoor coverage issues.
hi , thanks for your response and apologies for my lateness in answering . The problem I'm having is that my phone reception is poor in my house , even with my phone connected to my wifi/internet connection . Can anyone suggest a reasonably priced option that will improve my reception ? Thanks , Charles .
The recommended solution to indoor coverage issues, which are unavoidable sooner or later, is WiFi-calling. It allows full use of your phone for the same functions as with mobile network coverage.
If you also have poor WiFi coverage from your home router, then resolving that is the solution to both issues.
If your phone has good WiFi coverage but you're having problems with calls & texts, then you may inadvertently not be using WiFi-calling.
Does your phone show the WiFi-calling indicator when you have problems using it indoors?
@char109   Try relocating the router to a different location.  If it’s close to a TV you deemed to move it.
