on 22-09-2023 04:53 PM
I received a call two days ago. Today I have no network at all. Not able to make a call, send a text or even select a network.
Are there currently serious network issues in York?
on 22-09-2023 05:19 PM
If you have no network coverage, or access to WiFi-calling, then any network-based functions should be expected to fail.
Use the "check status" option on the webtool to check for known issues in your specific location - https://coverage.ee.co.uk/coverage/ee
on 22-09-2023 05:45 PM
That says I should have 3 bars.
I have zero.
on 22-09-2023 05:50 PM
You have used "check coverage" not "check status" as suggested.
The "check status" option includes the facility to "report a problem" if nothing is listed or register for updates.
on 22-09-2023 06:09 PM
Check status tells me there are no issues in the area
"No known problems in YO24..."
Problem reported
