There is no single on my daughter‘s phone
Tractor-1
Alex_H
Hi @Tractor-1,
Welcome to the EE Community
If your daughter is the only one on EE at the same location, I would recommend checking first for any local issues that might be causing her to have no signal.
If you have not already I would follow the basic steps and device guide steps available on this page. If nothing has fixed it then please give our technical team a call who will investigate the signal issue further.
Alex
Alex_H
Hi @Tractor-1,
Alex
