06-06-2024 11:44 AM
Hello,
I used to consistently and reliably get 4G in the south of Cambridge but recently (for at least a week) only get 2G. The satnav struggles, opening websites is slow etc. and I see the dreaded 'E' by the signal strength indicator. Any idea what's happening?
06-06-2024 11:47 AM
My phone is not 5G compatible hence no 5G in the screenshot above I guess.
06-06-2024 12:10 PM
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. Do you get 4G coverage in other locations?
06-06-2024 12:20 PM
Thank you for the link. It shows 'excellent' for 5G, 4G, and 2G, no coverage for 3G.
I don't travel much and far, I might have seen occasional 4G reception but it would've been a rare and brief occurrence these days. I'll be trying with another phone shortly, see if anything changes.
06-06-2024 12:24 PM - edited 06-06-2024 12:29 PM
Sounds like you've used the "check coverage" link, not the "check status" that is better in this case. There are subsequent options to "report a problem" if you're confident this is not a device-issue.
Please also ensure you have toggled flight mode if you've not done so already.
06-06-2024 02:52 PM
Ah right, yes. So I checked the status now and I have two accounts for some reason. I don't know what account is linked to my number but I checked with both:
Interesting that no one contacted me about this "problem". I wonder how long before someone would if ever.
Meanwhile I checked the other phone and it's also 2G there. I get the same stats as in the first post. 4G is enabled in the settings. I actually just witnessed a brief period of 4G, then the signal was lost completely for a moment and I'm now on 2G again. I'm not travelling or anything, sitting at my usual spot at home.
06-06-2024 04:24 PM
To get the area looked into and the message you have received when logging into the EE account, please call us on 150 and our tech guides will get this looked into for you.
06-06-2024 05:03 PM
I was advised that it's the first account that's linked with my number. But this doesn't help much since:
We can't check our network right now
Is the status check broken?
06-06-2024 05:30 PM
I am not aware of any issues for the status checker, are you using the EE app and going to the Help section?
06-06-2024 05:40 PM
No, I don't have the app, the wonky EE website is enough for me 😁 I simply followed the steps as suggested in this post:
https://community.ee.co.uk/t5/Mobile-Network-discussions/South-of-Cambridge-used-to-get-4G-now-2G-fo...
