Slow Data since engineering work
TheHedgeFairy
I have had this issue in xxxx xxx since they did work on a ‘local’ tower on 25/5/2023
I have got through to technicians on 3 occasions and they have said that they will send engineers out, I get texts saying that the engineer has visited and not found found a problem. One of the technicians did say that when they worked on the tower they may have slightly changed the angle of the data cell and
Me too
The last technicians did say that when they worked on the tower they may have slightly changed the angle of the data cell and that 1/2 a degree could make all the difference to my reception and  that he could see that  I am receiving from the voice cell and that my phone no longer ‘sees’ the data cell
I was able to cope with 36 mbps which is what I have had since I moved here in Sept 2022 but to go down to rarely achieving 1 mbps is virtually useless.
Just waiting until 8 am to fight through the first line operators to speak to a technician again . . . . 🙁
[Mod edit: Please do not post personal information on the public board. Thanks!]
Voice calls & mobile data both use the same network signal.
You're right to be pursuing this with CS. Any known issues should be listed on the website status tool.
