on 14-12-2022 09:40 AM
Since buying a Samsung flip 4, the phone signal in my House is awful, and frequently I get cut off mid-call! Any ideas out there how I can improve reception?
on 14-12-2022 12:07 PM
Hi @Lisylis.
Is the signal fine outside of the house and in other locations?
Are you using WiFi Calling?
Jon
on 14-12-2022 12:46 PM
The coverage you receive is what it is, if there was an answer to improving it everywhere then EE would have 100% national indoor coverage - something no network is ever likely to achieve.
Having said that - WiFi-calling is EE's recommended solution for indoor coverage issues where they occur.
Does your phone show a VoLTE/4G-calling symbol when your calls drop?
on 15-12-2022 03:59 PM
Yes, it's on my phone. Stupid question but how do I use WiFi calling?
on 15-12-2022 04:01 PM
Yes it's only in my House I seem to have this problem. Stupid question but how do I use the WiFi calling?
on 15-12-2022 04:17 PM
