Replacement sim
LindaLDB
My signal is very poor. Will a replacement sim improve this?
EssexBoyEE
Extremely unlikely, so No. Your best bet is to ring CS on 150 so they can maybe do some tests and check for issues in your Area.
EssexBoyEE
