Re: Zéro mobile network
BTea
Same here.
EE coverage map shows fully saturated 4G service for the area but the reality is a virtually unusable signal for months now.
-110dBm or worse most of the time.
Vodafone and O2 coverage is solid.
EE / BT repeatedly advise “use WiFi calling”.
There will always be localised variations with all networks.
If your phone is having issues across wider areas, I would suspect a device issue.
bristolian,
You may notice I said the Vodafone and O2 are fine - on the same device!
And another handset shows exactly the same poor coverage.
Some phones can still hold calls reliably below -115dBm, but it does sound like you've used the "check coverage" link rather than "check status" option
cje85
-110dBm isn't bad and should still be perfectly usable. 4G/LTE can work right down to -130dBm (sometimes even lower...)
