No signal
zoea93
I’ve suddenly no signal or very little, calls sometimes go through but after 5 seconds or so people are saying I’m cutting out call is going dead ect
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker  in the first instance, to check for local service outages. A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
