on 25-02-2024 05:20 PM
I've got exactly the same on both 7a and 8 pro
on 26-02-2024 07:41 AM
Hi @AClutt117,
What sort of issues are you experiencing with your signal?
Is it happening in a particular area?
on 26-02-2024 08:12 AM
It's happening all the time everywhere the signal just drops calls, WiFi calling is just as bad as home so I pretty much have useless handsets.
on 26-02-2024 08:52 AM
Hi @AClutt117,
If you're having the problem everywhere, it could be a device issue.
I'd recommend back up your phone and completing a factory reset to see if that resolves the problem.
