Re: My phone suddenly stoped working u cand send or recive calls or text.
TMZ
same problem here - EE unavailable
TMZ
service status shows "checking problems in your area". can't make or receive calls or messages
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker  in the first instance, to check for local service outages. A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
