Re: Looking for compensation!
Glenn1888
Having the same here Phone/mobile data and home BB
I am disabled so I need these things to work when I need them too
6 REPLIES 6
Hi @Glenn1888
Are you reporting problems with EE mobile services, and also EE home broadband?
They will be separate faults if so.
You can check for known issues on EE mobile using the "check status" option on the coverage tool
Glenn1888
Mobile no coverage calls or data went off Sunday morning did come back on Sunday night, first time I have left the house since was 5pm today no service AGAIN I am disabled I need this to work!!
Less than happy
Glenn1888
Cant check status as oneplus 9 is not available DOH!
You can safely choose the nearest equivalent phone to get a valid network-status search.
It would also be worth restarting your phone as a precaution.
@Glenn1888 , you just need to put your postcode in and then just enter any phone it then should work and  then you should be able to check status.
@Glenn1888 : You may be due for some Automatic compensation for the home BB.
