Re: Can't make or receive calls on either landline or mobile (both BT/EE)
Virgh1
I have exactly the same problem. I have driven down the road to get a sognal but neither ee number works nor bt.
15 REPLIES 15
No it doesn’t connect anywhere
Leanne_T
Thanks @Virgh1
In this case please call us again from any other phone on 07953 966 150 and our tech guides will get this looked into further for you.
How do i get someone to ring me??? I can’t find what i need on the app or website.
Sent from my iPhone
Christopher_G
Were you able to try calling from another phone, @Virgh1.
Once you're able to get through, our customer care team will be able to look into this for you. Are you near an EE Store?
Virgh1
Sorry i gave up. Will try again when when i build up my patience…
Solution at last ….
E Sim. Choice of Personal calls or Primary calls.
choosing personal or both does not work if you only have one phone number on your phone.
according to the EEshop i visited today. The technology isn’t fully sorted yet and it gets confused.
this happens on some phones but not all.
hope this helps others
