24-06-2024 09:53 AM
I have exactly the same problem. I have driven down the road to get a sognal but neither ee number works nor bt.
25-06-2024 07:10 PM
24-06-2024 10:07 AM
@Virgh1 You need to check that your mobile has wi-fi calling feature and if so is working may help if you have a landline issue, if cell is not able to send the text to your mobile, try switching it off and back on, may help text to come in. HTH
24-06-2024 10:14 AM
24-06-2024 10:30 AM
@Virgh1 Looks like you have to check with EE CS for mobile issue's, it may not be the iphone with the issue and possibly the service. Do you not have a good indoor EE mobile signal at home?
24-06-2024 10:38 AM
24-06-2024 10:41 AM
@Virgh1 Is there any of the major mobile providers that have a good signal at your home?
24-06-2024 12:37 PM
24-06-2024 02:01 PM
Hi there @Virgh1
Thanks for coming back to us.
Are you able to try the EE SIM card in another phone to see if the same happens?
24-06-2024 02:16 PM
My husband was with BY and his line was changes ee. He can tpe in 150 but there is no ringtone.
24-06-2024 02:24 PM
Hi @Virgh1
Are you both connected to WiFi and using WiFi Calling?
Does the call to 150 connect when you are in another area?
