on 10-07-2024 06:00 PM
Has anyone else signal completely gone of there phone been working all day battery died at work cam home charged my phone now it says no service tried everything
on 10-07-2024 06:15 PM
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
