Phone connection
Pkevin93
Is there a problem in the Darwen area as I have not been able to phone or text for most of the day
6 REPLIES 6
Northerner
Hi @Pkevin93
Have you checked EE network status: (check status)
https://coverage.ee.co.uk/coverage/ee
Hi yes but it says no known problem, I think I will call into my local store thank you
Northerner
Hi @Pkevin93
Have you tried restarting your device.
Yes I have tried everything including restarting phone, it even says I am connected to WiFi but still no joy.
I do keep getting "no service" at the top of my phone
The coverage webtool has a "check status" option which you can use to check - https://coverage.ee.co.uk/network/ee
After a check, you can "keep me posted" or "report a problem" depending on the outcome
Hi, many thanks I have now reported it as a problem and will receive an update within 24 hours
