09-02-2026 02:54 PM - last edited on 09-02-2026 04:55 PM by Peter_W
My data isn’t working it’s just has no service
09-02-2026 05:08 PM
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
09-02-2026 05:50 PM
Hi @Alice1233
Are you on EE PAYG or pay monthly contract.
Are you in the UK.
Have you tried restarting your device.
