No Service in Darlington and surrounding areas
Jakebf2001
Since around 1pm on Tuesday 29th July, I haven’t been able to get any mobile service whatsoever.
Is anyone one else having the same issue or is it my phone that is playing up?
Many thanks.
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker  in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
