on 06-08-2024 12:03 AM
I’ve just placed an order for a new phone, the question is this, do EE have a Network checker app like O2 do, so that if I have a weak or no signal I can check via the app where’s there a fault with the mobile network.
06-08-2024 12:12 AM - edited 06-08-2024 12:12 AM
Hello @robh661
You can check EE's Network Coverage and Report issues Check Mobile Coverage
I don't think EE has an App for their Network Coverage.
on 06-08-2024 12:24 AM
Thanks, I just gave it a try.
on 06-08-2024 08:57 AM
The MyEE app does have an option for logging poor coverage, it's not very well publicised though.
It's under the settings menu, Settings & Permissions > App Settings
