Network problem
fardinpahonchiy
Alex_M
Star Contributor
Star Contributor
Hi @fardinpahonchiy
What problem are you facing? If it is network connectivity related, I'd recommend checking for problems in your area using the Network & Coverage Tool.
Put in your postcode and choose your phone model, then click 'Check Status'.
https://coverage.ee.co.uk/coverage/eehttps://coverage.ee.co.uk/coverage/ee
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
