Network not working - how do I fix?
mcaq
Valued Contributor
Valued Contributor
For the past 24 hours at least anyone who tries to ring me gets  the message ' I'm sorry this number  is temporarily unavailable.......' . Yet I can dial out, send texts and have data. What is going on?
mcaq
Valued Contributor
Valued Contributor
Sorted - needed a network up date from Technical support. 3 tries to get through then an hour on hold/in call. Bit frustrating as no real explanation for the problem given.
7 REPLIES 7
Alex_M
Star Contributor
Star Contributor
Hi @mcaq
I'd recommend checking for problems in your area using the Network & Coverage Tool.
Put in your postcode and choose your phone model, then click 'Check Status'.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
mcaq
Valued Contributor
Valued Contributor
Everything works normally except for incoming calls via the SIM. Hence the network is working.
James_B
EE Community Manager
Hi @mcaq,
What type of phone is it?
Could you have inadvertently turned on a do not disturb mode?
mcaq
Valued Contributor
Valued Contributor
Thanks but no, checked  all that and moved between SIM1 and SIM2 so narrowed down to an incoming call issue. Tried to get help via 150, automated system says it will do a diagnostics and send me a text but that was over an hour ago and nothing ( I am receiving text massages)
James_B
Hi @mcaq,
Have you received any updates yet?
If not, I'd recommend calling Technical Support so a member of the team can take a look at it for you.
mcaq
Valued Contributor
Valued Contributor
James_B
I'm happy to hear it's sorted @mcaq 🙂
Sorry to hear it took a while to get through.
Have a great weekend.
