Network Down in ML10 6** AGAIN!!!!!
Detritus22
The network coverage is constantly dropping out in Chapelton!
The website always tells me there are no problems in my area but I know that there are and I know I am not the only one having issues!!
I moved from BT to EE but I am seriously looking at moving to another network!!
<mod edit: removed full postcode from title>
1 ACCEPTED SOLUTION
Christopher_G
Thanks for reporting it, @Detritus22
That will help our Network team identify they problem and work with our engineers to fix it as soon as possible. Thank you for your patience so far. Please keep us updated on what happens.
Northerner
Hi @Detritus22
Have you reported a problem  https://ee.co.uk/help/service-status/mobile
Are you having problems indoors or outside.
Have you tried restarting your device.
There is no signal either inside or outside.  The signal here drops out on a regular basis. There must be a mast locally that has an ongoing issue.  Thanks
Yes I reported the issue thanks
Christopher_G
