My business uses BT broadband speed boost
Kevin2917
My business uses BT broadband speed boost, with the EE 4g signal providing the boost, this has worked well until recently, how do I find out if the local 4g signal is down,without a EE phone as I am on a different network?
Have you Checked Status of the Network Status Checker there and reported your problem via that link?
Kevin2917
The Network Status Checker does not work, the only option I had was to call. I can check the network status on the other three providers but not the EE one
Leanne_T
Hi @Kevin2917
Did you call us to check if there was any issues in the area?
What happened when you entered your postcode on the EE Coverage & Network Status Checker | Check your signal?
