on 15-12-2024 01:33 AM
Hi excuse me my SIM card is not working I don’t have a signal today morning was working but now no signal
Solved! Go to Solution.
on 15-12-2024 08:23 AM
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
