Mobile data
George240
What is going on with the mobile data ?
Christopher_G
Hi @George240
Welcome to the community.
If you could answer @bristolian's questions, it'll help us give you some specific advice/help.
The first thing to try with mobile data issues is restarting your device, or turning 'airplane mode' on and off again.
If it still isn't working, you can check for issues in your area on our network status checker.
Let us know how you're getting on please.
The obvious answer is "I don't know, what is going on?" - but can you explain the problems you're having with mobile data?
Is it location-specific? Is mobile data enabled on your phone? Can you make & receive voice calls OK?
Christopher_G
Hi @George240
