12-07-2023 03:57 PM
not working anyone else’s mobile data just stopped working? And I can’t receive or make calls. I’m in brentford west london
12-07-2023 04:07 PM - edited 12-07-2023 04:08 PM
Hi @Pula2000
I'd recommend checking for problems in your area using the Network Status & Coverage Tool.
Put in your postcode and choose your phone model, then click 'Check Status’.
Make sure you tap check status and not check coverage.
Thanks,
Alex
12-07-2023 04:17 PM
Hi @Pula2000
Thanks for posting.
This looks like the SIM is not registering on the phone, are you using an eSIM?
Have you made any changes to the phone or your account today?
Leanne 🙂
