05-11-2022 08:09 PM
I have no signal in my house. Can i but an ee signal booster. My wifi signal is good but the ee signal is awful.Help!
05-11-2022 08:26 PM
@Nikki7202 EE no longer sell them sell them as they are being deactivated if anyone has one. They operate on a 3G signal and that service is being shut down. Can you not use Wi-Fi calling? This is the replacement for a signal box
06-11-2022 09:06 AM
There was never really any such thing as a signal booster, but in the past EE provided a 3G signal box that used your home broadband to connect back.
That is now old tech, and WiFi-calling is the recommended solution to any indoor coverage issue.
You've mentioned having good WiFi, so if you enable WiFi-calling on your phone, then you can continue using it without any regard for mobile coverage. Any calls will also handover between WiFi-calling & the 4G-mobile network if you move in or out of coverage - not possible with the 3G signal box.
