LTE Band 1 lost in Cambridge area?
radiomean-uk
Valued Contributor
Valued Contributor
Hi, this is very strange.
I've been using cellular modems and routers for a long time and am experimenting with Quectel RM551E-GL modems.
In my Cambridge area, up until about two weeks ago I got about 800 MBit/s download on 5G-NSA.
I was connected on 5 bands - B3 primary, B3 secondary 1, B1 secondary 2, and two n78 bands.
However, B1 disappeared about two weeks ago and I only got 4 band connection, and my download speed literally halved, to 400 MBit/s.
I can't see B1 on EE anywhere in Cambridge, either on a router/cellular modem or on my phone (Fold 6). Can anyone shed any light on this? (If I change to a 3 sim, I get B1 connection so it's not an issue with my devices)
Thanks!
20 REPLIES 20
Hello Christopher, as I said down this thread, I've already checked service status - 'no faults' - and reported a network issue a couple of times, but I have had the message back 'no faults found'.
I will have to follow up in more detail with the tech support team...
Well, I can say that with band 1 I got up to 800 meg down, and without it I got 400-500 meg down - and there was no other change...
You're lucky you can even check the network status 😀 I've been trying for several days and I keep getting the same response….we can’t check our network right now 😡
@prophilips1 wrote:
I think it is ‘globally’ switched off
You'd be wrong.
@prophilips1 wrote:
the rest of working band 3 and 7 is a total failure !!!
Again, not my observations.
You likely have a local fault.
Chris_S
Hi @prophilips1
I'd recommend following the advice that @Christopher_G has given and contacting our Technical support team so that they can take some details and run some checks for you.
Chris S
Yes thanks, I'll follow this up soon. It has now been in this situation for around a month - I wanted to leave a decent time incase it was resolved without me taking any action.
Cheers!
cje85
@bristolian wrote:
@radiomean-uk wrote:
Furthermore, I've driven around in East Anglia a bit in the past two weeks and haven't seen band 1 on EE at all, so I wonder if they've 'globally' switched it off, for some reason?
it may be a regional or localised choice, B1 is still present in my corners of Bristol & Gloucestershire.
Losing that 15Mhz carrier should not cause that degree of performance drop alone. Reconfiguration of carriers is a BAU activity, you may struggle to get any traction out of CS there - but good luck with your efforts.
Yes, a standard 15MHz Band 1 LTE deployment will provide 112.5Mbps theoretical maximum (real world speed will be less) so the loss of that band alone wouldn't cause a 400Mbps speed drop.
Is this likely to be a reason for an issue I’ve had in Cambridge over the past few weeks where my iPhone 17 pro shows signal but doesn’t get any data. I have to put it into airplane mode and back on for it to work again. Never used to happen at all
This should not be a reason for your symptoms. Lack of L2100 where it's been present before isn't even necessarily a fault, it may just be a reconfig to NR2100 instead.
Does it make any difference if you are on a call when you try using mobile data?
Can’t make calls when it happens. I’m home now away from the place it happens and fingers crossed as usual it’s fine there.
