LL14 cefn mawr wrexham no data
robbyj
Valued Contributor
Valued Contributor
HI All.
anybody having issues with data on ee with using data on a 2/3 bar signal in the cefn/trevor/carefiar area of wrexham?
been like this for a month now , can make calls and texts but anytime i try data it always fails until i leave the area and it works again ?
20 REPLIES 20
James_B
EE Community Manager
Hi @robbyj,
Does the Network Status Checker report any problems in the area?
Wrexham is in an area where 3G coverage has now been switched off, so if your don't have a 4G phone then you will be using 2G permanently - explaining your symptoms.
What phone are you using, and are you on an EE plan?
robbyj
Valued Contributor
Valued Contributor
Hi James,
im in a 5g/4g area and everything is fine using the network status checker.
regards
robby
robbyj
Valued Contributor
Valued Contributor
hi ,
i have an iphone 15 pro and i am on the unlimited 100gb plan with EE.
my girlfriend has the iphone 14 pro max and she has same issue with EE in this area.
regards
robby
Katie_J
Thanks for confirming this @robbyj.
Are you aware of anyone else experiencing this?
Katie
Does your phone show 4G coverage when you have this problem?
robbyj
Valued Contributor
Valued Contributor
Hi Katie , yes there are a few people in the area I know of that h
ave complained over the phone but get no help , but it might be a problem with the transmitter at LL20 .
ive seen a whole group post about it on Facebook
regards
Robby
robbyj
Valued Contributor
Valued Contributor
Hi , yes I have 4g and I’m able to make calls and text , but no internet.
You can't go round publishing the full names of 3rd-parties on a public site.
