I can’t access duluxdecoratorcentre.co.uk on EE mobile
johnners1969
As above. But, if I use a VPN, I can. I can access it using WiFi and other mobile providers can access it. What’s going on with EE mobile?
Btw, I am a decorator and need to access it.
Thanks for any help.
11 REPLIES 11
DJW-20
You'll only have private relay if you are an icloud subscriber and you've enabled it.
I've seen @Ali_A has picked up on this and it'll be on the road to getting fixed. Might be worth staying on the VPN for now
I am NOT an EE staff member, but I'm still happy to help! I cannot access your accounts
24m EE essentials Max
BT 900mbts FTTP
