28-02-2023 09:38 PM
My phone has been failing both incoming and outgoing calls
It works fine after a quick restart, but such a pain to keep doing this
Not really any network issue
What could be causing this?
01-03-2023 08:23 AM - edited 01-03-2023 08:23 AM
Hi @Leah0510
Thanks for coming here.
Does the Network Status Checker report any problems in your area? (Please select the 'check status' option)
Are you able to try the SIM card in another phone to see if the same happens?
Leanne 🙂
01-03-2023 09:23 AM
Network status is fine, I checked that before asking, I dont have another handset to try
Also made sure WiFi calling is off, but still having the same issue
01-03-2023 09:25 AM
Thanks @Leah0510
I would suggest giving us a call on 150 and the team will get this looked into in more detail for you and let you know the next steps 🙂
