19-03-2023 10:01 AM
Hi
I have had a phone upgrade, I have stopped my sim over and only get emergency calls, I can't even ring 150.
Has any1 got any ideas on how to fix this?
19-03-2023 10:04 AM
Morning @Howardburrows89
Thanks for coming here.
Have you registered the new SIM card?
Does the old SIM still work?
19-03-2023 01:00 PM
A replacement SIM is often supplied with upgrade phones incase there is a problem with your existing SIM or it doesn't fit.
If your current SIM is working and fits your new phone, then simply swap it over. If you have registered a new SIM, then check whether your old SIM or new SIM works in your old phone - and use it in your new phone.
