EE Auto Wifi
BeardedClaw
Hi so I used to always be able to connect to ee wifi underground automatically - however I now have to select manually at any stop to just connect to it. Any advice/tips to resolve?
iPhone 12 Pro max ios 16.0.2
7 REPLIES 7
Northerner
Hi @BeardedClaw
I noticed this in my S21 Ultra last week.
I'm back in London tomorrow so I will see if it's the same issue.
roseytea
Did you manage to resolve this? I’ve had the same problem for 3 or 4 months now. Have had several calls to EE but unfortunately no success. I’m using an iPhone 12
Katie_J
Hello @roseytea.
What was the outcome of your last call to technical care?
Katie
They updated my profile via text message but unfortunately upon returning to the underground it didn’t work. They have asked me to call from the underground but the times I’m there - to and from work at peak time - it’s a bit difficult to!
Katie_J
Are you experiencing the same issues as the original poster? @roseytea.
Katie
Yes, exactly the same.
Katie_J
Thanks for confirming @roseytea.
The only thing I could now recommend after your profile being updated already is to try follow the advice from our technical care team and call when at the station.
I am aware that this can be a bit difficult especially during rush hour.
Katie
