05-06-2024 03:53 PM
Do I need to request 5G or should it just work?
I entered into a 5g plan a few months ago when I only had a 4G phone, I now have a 5G capable phone (Google Pixel 7a) but I'm still only getting 4G. Can anyone tell me if I need to request 5G or should it just work?
06-06-2024 12:02 PM
Hi @Leanne_T
My phone downloaded Android 14 update during the night and hey presto, I now have 5G
05-06-2024 03:56 PM
If you already had a 5G-plan, now have a 5G-phone, and are in a 5G coverage area, you should receive 5G services.
Use the coverage checker tool to see whether you are in a 5G-enabled location - https://ee.co.uk/help/mobile-coverage-checker
05-06-2024 04:07 PM - edited 05-06-2024 04:08 PM
Apologies, I should have added that the coverage map states good 5G coverage outdoors and not so good indoors but my phone continues to report "4G" on the screen next to the mobile network icon regardless of me being in or outdoors
05-06-2024 05:24 PM
Hi there @Happy2Strum
Thanks for coming here 🙂
Have you been able to try other areas to see if you have 5G signal?
Is there anyone else in the area that you know on EE and have 5G showing?
Leanne 🙂
05-06-2024 05:46 PM
Hi @Leanne_T
I only set the phone up this afternoon so I haven't had a chance to delve into the problem in any depth yet, I just thought I'd ask the question first to make sure that the phone should be working on 5G before I started chasing a problem that doesn't exist.
05-06-2024 05:46 PM
I see @Happy2Strum
Please let us know how you get on after using the phone in other areas and see if 5G shows available 🙂
06-06-2024 10:32 AM
I have a similar issue. Just got a new phone (pixel 8a) and my esim in it won't connect to 5G in 5G areas whereas it would in my old phone... Wondering if any solutions out there!
06-06-2024 11:55 AM
Hi @Pomeroy784
Could you check your phone settings and see if 5G is showing in your network settings?
Leanne 🙂
06-06-2024 12:02 PM
Hi @Leanne_T
06-06-2024 12:12 PM
Thanks for coming back and letting me know @Happy2Strum
Leanne 🙂
