Coverage in Twinbrook and Derriaghy
Christopher_G
Update: 25 August 2026
Over the past few days, our engineers have installed the transmission and the new mast is now on-air.
We are continuing with the third location for another mast to fully restore service to the area. Our engineers are continuing legal negotiations with the site provider, to legally acquire the land and agree planning permission.  Pending a positive outcome from the legal steps, we can start building the equipment needed for the new mast and confirm an approximate on-air date.
We will keep you updated on this post.
Update: 29 July 2026
Due to circumstances outside of our control, we have been unable to complete the work needed for the transmission by the middle of July. Barring any further unforeseen circumstances, we expect the transmission to be installed by the end of August and the mast to be on-air by the beginning of September.
Update: 11 June 2026
Over the past few weeks, we have experienced a slight delay accessing the area, to install the transmission needed to integrate the mast onto the network. Barring any further unforeseen circumstances, we expect all work to be completed and the mast to be on-air by the middle of July.
Update: 19 May 2026
Over the past few weeks, the power company has installed the power supply. We're working with the site provider to access the area and install the transmission and start integrating the mast onto the network. Barring any unforeseen circumstances, we expect all work to be completed and the mast to be on-air by the middle of June.
Update: 18 April 2026
Over the past month, our engineers have been working with the power company to arrange a date to install the power supply, barring any unforeseen delays, we expect the power supply to be installed by the beginning of May. Once the power supply has been installed, we can start integrating the mast onto the network and confirm an approximate on-air date for the new mast.
Update: 06 March 2026
Over the past few weeks, our engineers have completed the work on the first mast to improve 5G service in the area.
For the second location, the tree has been removed by the contractors. Our engineers are working with the power company to arrange a date to access the area and install the power supply needed for the new mast. Once we have a date for the power installation we can confirm an approximate on-air date for the new mast.
Update: 12 February 2026
Over the past few weeks, our engineers have experienced a delay completing the work needed on the first mast to improve 5G service. Due to the location of the mast, to access the equipment we require an elevated work platform to access the equipment and have been unable to secure this before the end of January. Barring any further unseen delays, we expect the work to be completed by the end of March.
For the second location, our engineers require a tree to be removed to access the power supply. We're working with contractors to arrange a date for the tree removal. Once the tree has been removed and the power company has installed the power supply, we can confirm an approximate on-air date for the new mast.
Update: 07 January 2026
Over the past month, our engineers have completed additional work on the first mast to improve capacity and service in the area. The mast currently has an open service ticket for 5G performance, we expect this to be resolved by the end of January.
For the second site, we have built the equipment needed for the new mast and have found further work is needed at the area before the power supply can be installed. Once all work has been completed and we have a date for the power company to install the power supply we can confirm an approximate on-air date for the new mast.
We are aware of a mobile signal issue that is affecting some of our customers in the Twinbrook and Derriaghy area. Our mast in the area had to be removed from the existing site at the end of November 2025, as this was requested by the land owner.
As soon as we were made aware our equipment would need to be relocated, our engineers began looking for a new location for the mast. To restore the same level of service in the area the previous mast provided, we will require three new masts:
The first site is live and working, but is in the process of being improved. All going well, this should be completed by the end of December and will improve service for affected users.
The second site is built, but is awaiting power supply. Barring any unforeseen circumstances, this should be completed by the end of February 2026.
The third is awaiting surveys to make sure the location is suitable for the equipment.
We will post any updates here.
We’re sorry for any inconvenience caused. In the meantime, you may be able to use WiFi Calling to make and receive calls and texts over a WiFi connection.
For information on who can use WiFi Calling and how to set up this service, please see our Using WiFi Calling Help page.
18 REPLIES 18
Orrsio
Hi, my postcode is in BT17 - my phone signal is very poor. I work from home and need a good signal, the mast that was removed from the tower block in November had been ongoing for over a year, why was this not envisaged by EE a long time before…
I will definitely have to move to a better provider if this is not sorted.
and yes I have WiFi calling on. My broadband is with sky and not EE, will I get reimbursed for using this..
[Mod edit - postcode removed, please don't share this in full in public]
I am BT17 as well , and I can’t even use wi fi calling , it does not work in the house . The only place I can get signal is upstairs in a back bedroom . Even with the first mast up & running , it is no better than.
I think my only option is to move provider. My neighbours are using Three & have good signal inside the house .
There's no reason for this to be the case. Perhaps start a new thread explaining the issues you're having with WiFi-calling, and whether you've been able to use it previously.
Kj158
Any update?
Jprussell
Wifi calling not even working now. When I do manage to call it just goes to answer machine on other ee devices
Leanne_T
Hi everyone.
The main post has been updated with the latest updates.
Kj158
Any update
Signal is still very poor
Annoyedcust
Any update.
Have reported this at least 4 times and each time they have to reimburse me or restart my network settings
Wifi calling isn't even working anymore have to forward all calls to another provider as waiting for important phone calls
Ali_A
HI @Annoyedcust
Any updates will be added to the main post on this thread.
You can also sign up for updates at Service Status checker | Check Your Network | EE
If you're facing a problem with your WIFI calling service please give Customer Service a call, where a guide in the technical team will be able to investigate and reset your WIFI calling service on your line.
Ali
