Coverage in Redbridge
Leanne_T
Update: 20 July 2023
Over the past week, our engineers have completed installing the mast onto the network, and the mast is now on-air restoring coverage to Redbridge.
We will continue to monitor performance in the area.
Update: 11 July 2023
Our engineers are expected to complete building the equipment needed for the new mast by the beginning of this week. Once the build is completed, we can start integrating the mast onto the network. Barring any unforeseen delays, we expect the mast to be on-air by the end of July.
We will keep you updated on this post.
Update: 08 June 2023
Over the past month, our engineers have started building the equipment needed for the new mast and expect the equipment to be built by the beginning of July. Once the build is completed, we can start integrating the mast onto the network. Barring any unforeseen delays, we expect the mast to be on-air by the end of July.
Update: 11 May 2023
Over the past month, our engineers have been working with the landowner to access the area and start building the equipment needed for the new mast. Unfortunately due to logistical planning we have experienced a slight delay starting the build. We expect all planning to be completed by the end of next week and the build to start by the end of May. Barring any further unforeseen delays, we expect the mast to be on-air by early July.
We are aware of a signal issue that is affecting some of our customers in the Redbridge area. Our mast in the area had to be removed from the existing site in March 2023, as this was requested by the landowner. Our engineers began looking for a new location as soon as we were made aware our equipment had to be removed, and we have located a new area. We have completed the required designs and surveys to make sure the land will be suitable for the equipment. Our engineers are working with the landowner to arrange access to the area to start building the equipment needed. Barring any unforeseen delays, we expect the new mast to be on-air by the end of May, restoring full service to the area.
We’re sorry for any inconvenience caused. In the meantime, you may be able to use WiFi Calling to make and receive calls and texts over a WiFi connection.
For information on who can use WiFi Calling and how to set up this service, please see our EE WiFi Calling: All you need to know, article.
36 REPLIES 36
Leanne_T
Hi @Mangs
Thanks for posting.
If you are having signal problems at this area, you can report this on the network status checker and this will be looked into for you. If you select 'check status' and then report.
Thanks 🙂
@Leanne_T i too have experienced this ever since new mast online. At times in my house I get 1 bar and other times no service whatsoever. This compared to full bars before the whole farce of a situation. I have reported it 4 times in last 2 months and nothing happens. I get an automated message saying it’s being looked into and a few hours to a day later, I get a message saying all fixed and case closed with no change whatsoever. How can you put us through this level of nonsense and incompetence. I don’t want my complaints being automatically closed on your end, I want it open until the issue is actually resolved. How is this anything but absolutely cruel and shoddy customer service?
Leanne_T
Hi @Reddevil786
I am very sorry to hear you are experiencing signal issues in the area.
If you call us on 150 and select technical support,  the team can take a detailed look into the area and give you an update.
Thanks.
Back to one bar signal again, this is really fun, NOT!
Leanne_T
Hi @Reddevil786
Thanks for posting.
If you are having signal problems in this area, you can report this on the network status checker and this will be looked into for you. If you select 'check status' and then report, the network team will keep you updated.
Thanks.
Hi Leanne. I’ve reported on network status checker a couple of times but apparently no problem found. However myself and every visitor on EE only has one area in my residence now, despite having full bars prior to March.
Katie_B
Hello @Mangs
If you are continuing to experience issues please give us a call on 150.
Katie
