Coverage improvments
Karen401
I have recently moved house and have very poor coverage on both 4g and phone signal. How can i find out if there are any plans to improve this or should i be looking to change network?
@Karen401 : Have you checked the Network Status Checker there and reported your problem via that link?
With the best of intentions, network rollout comes with very fluid timelines and exact details are known only internally.
Having said that, if your phone supports WiFi-calling, indoor coverage issues should not be a problem - the facility enables you to call & text without any requirement for mobile coverage.
You should also get seamless handover of calls between WiFi-calling indoors and 4G-calling outdoors.
I don't think there is a specific problem just poor coverage in the area.
Should I still report it?
Hi thanks for the reply. I am also having an issue getting WiFi installed
so relying on very poor 4G just now.
The online coverage tool has two functions;
1: "Check coverage" looks for predicted coverage in your area
2: "Check status" searches for known faults & issues in your locality, with the facility to report issues if not known.
What does the coverage check advise - does it reflect your experiences? If not, do other EE users have similar problems in the same location?
