26-09-2023 05:44 PM
For the last two days I can’t make calls, when I dial it immediately gets cut off: call ended. I have 10000 minutes until 22 October. Are there any issues with the network?
26-09-2023 05:56 PM
Can you receive calls OK? Does toggling flight mode make any difference?
You can check for local coverage issues on https://coverage.ee.co.uk/coverage/ee under "check status"
26-09-2023 06:51 PM
I can receive calls. I removed sim, cleaned it and it seems to be working now. I hope it will be ok
