31-12-2022 10:16 AM
Morning - I am using a huawei B525 4g router and getting 40Mbps download but only 0.4 upload. When I check it, the rate is good for moment and then collapses as though it is being being clamped somewhere. Any ideas?
HNY
31-12-2022 10:28 AM
Forget speed check. Are you having and real world usage issues?
31-12-2022 08:47 PM
Thanks for the advice Grand Master I have now forgotten my use of speed check. However I still find 'real world' uploads are very slow, almost as though the asymmetry between download and upload speeds is wrong or at least biased too much toward the download. I suppose I could check the speed to find out but that seemed to be the wrong approach. Is there another way?
01-01-2023 07:33 AM
Do we have any problems reported on the EE Network Status Checker for your area?
01-01-2023 11:52 AM
No reported problems but I did get this - am I doing something wrong?
02-01-2023 09:13 AM
Does anyone have knowledge of the correct settings for a Huawei B525 router? Should I be looking at replacing it? or is it a network/sim issue. It seems to have got worse. Thanks
03-01-2023 08:27 AM
Hi @gardwell1961
I would recommend having a chat with our Technical Support team so they can look into this for you.
