28-01-2023 04:12 PM
28-01-2023 04:08 PM
29-01-2023 07:41 AM
Welcome to the community.
Are you getting any error messages? Have you tried restarting your device?
29-01-2023 08:30 AM
Tried that and took to a phone shop they said my data is locked maybe used up allowance. I don't understand this as have had same for last 6 years and never used it over before ..
29-01-2023 09:20 AM
If you have ran out of data, you would still be able to activate it in the settings, @hayleycluskey18.
You just wouldn't be able to use any data apps without purchasing an add-on.
What kind of phone are you using?
29-01-2023 09:27 AM
I'm using the Samsung A53 5g. I never had problem with old phone a5 2017.i don't get any signal as soon as leave home and used to play my youtube music through Bluetooth in my car but can't get that either
29-01-2023 09:35 AM
Is it a new phone, @hayleycluskey18? Where did you get it from?
Is it the same SIM as you were using in your old phone?
29-01-2023 11:33 AM
Yes sane sim and phone off EE
29-01-2023 12:32 PM
OK, thanks @hayleycluskey18.
Could you try doing a manual network search and select a non-EE network. Once that inevitably fails, could you try manually connecting back to EE?
Let me know if that helps.
29-01-2023 01:07 PM
Don't understand that sorry
