Very slow internet speed on mobile
Jaymax
Hi. I’m using monthly 10GB plan but the internet speed is awful . Speed between 3Mb to 7Mb always, no matter at home or anywhere. Any suggestions?
6 REPLIES 6
Leanne_T
Morning @Jaymax
Thanks for coming here.
What device are you using?
Have you reported this on our EE Coverage & Network Status Checker?
If you select 'check status' this will show you if we have any reported issues for the area and if not you can report this to our network team.
Leanne 🙂
I am using iPhone 11
Leanne_T
Have you tried resetting the network settings? @Jaymax
To do this go into, Settings > General > Reset > Reset Network Settings only, this will restart the phone and remove any saved WiFi passwords you may have.
Yes I did, but now it’s getting worse, keep disconnecting.
Leanne_T
Thanks @Jaymax
In this case, please report this to our tech gurus by calling 150, they will get this looked into in more detail for you.
Leanne 🙂
Is this a recent problem?
