Unusual traffic message when using Google.
Dori007
Hi, apologies if this has been asked before. I can’t use Google while connected to WiFi. It blocks the search and then gives message that unusual traffic that goes against Google terms and conditions?? It’s been nearly a week now!  How do I stop it happening?
thanks in advance
Who's providing the underlying broadband connection, for the WiFi-router you're connected to when having this problem?
Do you have any issue using Google over EE's mobile network?
You posted under Mobile Data but you talk of WiFi. Which is it? WiFi is data coming thro' somebody's router.
Hi, it’s ok if I use my phone data but it’s when I connect to any WiFi
Then talk to your WiFi provider.
The you for your advice, condescending and a little rude but thank you anyway
