Unlimited Data Add On
bdg0514
i have purchased the 24hour unlimited data add on to save my 25GB plan data while I'm out. However, when i look in my EE i can see that my data is still coming out of my normal allowance instead of the 24hour Unlimited add on allowance? Any help with this?
@bdg0514   You’ll use your allowance before it uses the add on.
bdg0514
Ah ok thanks for clarifying. I've probably missed some small print or detail somewhere when I bought it. I just thought it wouldn't dent my plans data while it was active
